17 years agoporting code from SRAM to SSRAM, bursting confusion
Hi all, I'm trying to port some code which used an SRAM chip on a DE1 board, to use the SSRAM chip on a DE2-70 board. My main concern and confusion is the fact that SSRAM uses bursting. ...
17 years ago --- Quote Start --- I've done some testing, and the SSRAM chip I am using is capable of pipelining arbitrary addresses for reads. Just thought to clear it up. --- Quote End --- Indeed, and as a matter of fact, some SSRAM datasheets show waveforms for back-to-back reads without bursting. The question is then, why those chips has special support for bursting? Unless I miss something, you don't gain anything at all by using the ADV pin and the SSRAM internal burst counter. Special bursting makes sense on RAM parts with multiplexed row and column lines. But here there is no such multiplexing, so I don't see what is the purpose of bursting. Anybody?
