9 years agoPort number limitation prevents my codes from compiling
I have two questions. What I want to do is : I want to send 144 8bit numbers from my computer to FPGA, and let the FPGA store the numbers in memory in the FPGA. And let the verilog bloc...
9 years agoI Looks like you have declared all 144 numbers to be transferred to the FPGA via 1Byte each as separate Inputs (144 x 8 = 1152 I/O pads + (assumed) some control, clock, ...).
If this is the real Hardware implementation you Need a FPGA with enough I/O Pins (I'm quite sure there is no such housing). If the numbers are to be stored in internal Memory you normally have one 8Bit Port for the numbers and one 8 Bit port for the Memory address the number shall be stored at (2^8 = 255 "locations"). I think you need to re-check your code again...
