dvirbuc
3 years agopof file size and address in flash
hello
I am trying to determine the beginning address and finale address of the pof in the flash
how can I know where the pof file is stored in the flash, is it different for every FPGA?
how...
- 3 years ago
In your case the address in flash is 0x0 which is where it is stored. You may refer to this link for additional information :https://www.intel.com/content/www/us/en/docs/programmable/683698/21-1-19-1-0/implementing-page-in-the-flash-pof.html
Hope this clarifies your doubts.
Thank you.
Kelly
ak6dn
3 years agoAfter I finish a full design compilation and generating the .sof/.pof/.jic files, I am left with a file DESIGN.map.
It's contents are (this is from a 13.0sp1 CycloneII compile):
BLOCK START ADDRESS END ADDRESS Page_0 0x00000000 0x00076CA1 Notes: - Data checksum for this conversion is 0x00D518FB - All the addresses in this file are byte addresses
Which shows that the data starts at 0x0 in the config prom and is length is 0x76CA2 bytes.
