8 years ago
PLL's in Cyclone V
I am trying to use the output of a PLL to drive a logic in FPGA. I'm not sure which clock should be connected as the 'refclk' for the PLL and how the 'outclk' of the PLL should clock my logic.
I have tried using a 50MHz clock (PIN AF_14) as a refclk for the PLL, and used the PLL 'outclk' as a clock input but my logic does produce any output. Could you please help?
Also, when I check my logic in ModelSim, the correct results are obtained.
Thank you.
    Are you using development kit?
    Check/Monitor the clock 50Mhz refclk input Using signal-tap for the debug.
    Anand Raj Shankar
