16 years agopll reconfiguration and CP/LF parameters
Documentation describing the pll scan chain is clear enough for the settings of the m,n,cx counters. However, it is not clear to me how the charge-pump and loop-filter parameters should be calculated...
15 years agoHi I'm developing a pulse generator and I use the pll to generate the timebase, so I need to reconfigure it "dynamically".
jvov could share your script? maybe we could derive the formula through these data provided by megafunction... or meanwhile someone has found the CP/LF formula? thanks a lot! Alessandro Ruggeri
