TabetS
3 years agoPLL Phase-locked loop clock detection
Agelix 7 series chip hard ip is used to complete the project. Now the incoming clock is used as the special clock for transceiver, and the outgoing clock through syspll is also a special clock. Now w...
lixy
Contributor
3 years agoHi there,
If you want to check if the internal signal is normal, did you try using SignalTap to capture the waveform?
Thanks & Regards,
Xiaoyan
