16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-II with variable phases. Those two outputs should be phase-synchronized. They are going to drive two separate loads of 50 ohm for impedance matching. I wonder if the PLL can provide up-to 30mA for each output in order to drive those two loads of 50 ohm . If not, please recommand practical solutions. Many thanks.
