8 years ago
PLL of Cyclone V: 'reconfig_to_pll' bus description needed
Hi community,
I'm working on a Project that has to be migrated from a Cyclone III to a Cyclone V FPGA.
My problem is the PLL reconfiguration. Normally, the reconfiguration is processed by use of the PLL reconfiguration megafunction.
In my application, I can't use this tool. For the Cyclone III, we've created a own simple design to handle the scan chain. This was possible, because the scan chain is well documented.
Unfortunately, the PLL reconfiguration on the Cyclone V is completly different (it uses a 64Bit reconfiguration bus), and my problem is, that I could not find any description of the bus signals nor the bus timing.
My question is: Can anybody give me a hint, where to find this information? Or has anybody a description of the bus?
Find attached a screenshot that illustrates my question
1 Reply
    Altera/Intel don't publish the details of that bus.
    Can I ask why you don't want to use the PLL_RECONFIGURE IP - as is intended for PLL reconfiguration? You're clearly intending to do some redesign work in moving to Cyclone V from Cyclone III. Why not incorporate the PLL_RECONFIGURE IP and use the two bits of IP as intended? Controlling the PLL_RECONFIGURE IP is pretty straightforward...
    Cheers,
    Alex
