12 years agoPLL Megafunction actual clock frequency
Hi, I am using the Altera PLL Megafunction to generate 6 different clocks (100, 125, 200,50, 1MHz) with a reference clock of 100 MHz. I set all the frequencies correctly except for the 1 MHz c...
12 years agoI am using Arria v. I was just wondering why the 1 MHz that I had in the PLL turns to 1.9 MHz(actual clock frequency) when I add the 200 MHz clock. It seems the number of output clocks and their values influence each other. Thanks a lot everyone for your help.
