12 years agoPLL lock problem
Hi all, I have problems with the PLLs in a 5CGXFC7D6F31C6N. They don't lock. I can reduce my design to 4 PLLs as shown here: https://www.alteraforum.com/forum/attachment.php?attachmentid=8...
12 years ago --- Quote Start --- Hi, One ALTPLL has about 5 outputs, since you are using the same reference frequency to generate the out freq., why don't use a single ALTPLL? instead of 4 PLLs. Regards, Uday --- Quote End --- Actually, one of the Cyclone 5 PLLs has up to 9 outputs. But the generated frequencies are restricted to a common divider. If you need frequencies which don't match this criteria you need different PLLs. However, I solved my problem above, I forgott to connect a resistor to the RREF pin which then led to this very strange behaviour. Oliver
