Joossss's avatar
Joossss
5 years ago
PLL frequency doubling but shouldn't
Hey!
I'm using a PLL on Cyclone 10 LP to create a clock with the same frequency, but shifting the phase. The PLL works fine in simulation when I create a clock and feed it straight into the PLL. However, I need to have it working with a differential clock. So, I'm simulating a differential clock and feeding it through the differential input buffer (ALTIOBUF). Now for some reason the PLL doubles the clock's frequency. Image shown below. Is this an error with Modelsim, or how could I solve this issue?
I'd presume this issue arises due to the signal being undefined when they cross?
Thanks in advance!
  • Hi Joossss,
    Thanks for your code!
    I was able to reproduce the issue that you mentioned.
    In the screen shot that you had shared, the output of the LVDS_CLK_inst (buffer) is not clean. There are some red lines ('X') on the buffer output. Same happened in my code as well (see signal /top_tb/dut/clk_in) . Result was that the PLL output was double the input clock.
    Then in the test bench, instead of using the procedure clk_gen, I drove the differential clock inputs using simple process.
    SIGNAL clk_in_p : STD_LOGIC := '1';
    SIGNAL clk_in_n : STD_LOGIC := '0';
    PROCESS
    BEGIN
    clk_in_p <= not clk_in_p;
    clk_in_n <= not clk_in_n;
    WAIT FOR 6.6666 ns;
    END PROCESS;
    With this the buffer output was clean and the PLL generated the output as expected. See the screen shot.
    May be due to the 'procedure' there is an delta delay added to the input signals and they are not phase aligned to each other, so the buffer output is not clean.
    That impacted the PLL output as well.
    Regards.
  • Ash_R_Altera's avatar
    Ash_R_Altera
    Hi Joossss,
    PROCESS
    BEGIN
    WAIT FOR 6.6666 ns;
    END PROCESS;
    Regards.
    • Joossss's avatar
      Joossss
      Hey!
      Thanks this works indeed, I only tried to use this process, because I tried to solve the same issue with it, by introducing delays into one of the lines, because before this I used
      lvds_clk_p <= not lvds_clk_p after 3.3 ns;
      lvds_clk_n <= not lvds_clk_p; -- 150 MHz
      and this also didn't work.
      Anyway, thanks for solving the issue.
    Ash_R_Altera
    Can you please attach the piece of code showing connections from differential input pins to the PLL output?
    • Joossss's avatar
      Joossss
      Yeah sure.
      The VHDL code:
      ntity PLL_TEST is
      	Port (LVDS_Clk_p, LVDS_Clk_n	:	in std_logic_vector(0 downto 0);
      			clk		:	in std_logic;
      			step, updown	: in std_logic; -- step must be applied for atleast two cycles.
      			cntsel	:	in std_logic_vector(2 downto 0) -- "000" all counters, "001" M counter?, "010" c0 ... "110" c4
      			--data				: out std_logic_vector(15 downto 0)
      end PLL_TEST;
      architecture rtl of PLL_TEST is
      	component IOBUF_Differential_1
      	port(
      		datain	: in std_logic_Vector(0 downto 0);
      		datain_b : in std_logic_vector(0 downto 0);
      		dataout	: out std_logic_vector(0 downto 0)
      	end component IOBUF_Differential_1;
      	component PLL
      	port(
      		areset	: in std_logic;
      		inclk0	: in std_logic;
      		phasecounterselect	:	in std_logic_vector(2 downto 0);
      		phasestep	: in std_logic;
      		phaseupdown	: in std_logic;
      		scanclk		: in std_logic;
      		c0			: out std_logic;
      		locked	: out std_logic;
      		phasedone : out std_logic
      	end component PLL;
      	signal pll_clk					:	std_logic;
      	signal pll_lock				:	std_logic;
      	signal rst						:	std_logic := '0';
      	signal pll_phasedone			:	std_logic;
      	signal LVDS_Clk				:	std_logic_vector(0 downto 0);
      begin
      	LVDS_CLK_inst : IOBUF_Differential_1 PORT MAP(
      		datain 	=> LVDS_Clk_P,
      		datain_b	=> LVDS_Clk_N,
      		dataout	=>	LVDS_Clk
      	PLL_CLK_inst : PLL PORT MAP (
      		areset	=> rst,
      		inclk0	=> lvds_clk(0),
      		phasecounterselect => cntsel,
      		phasestep => step,
      		phaseupdown => updown,
      		scanclk	=> clk,
      		c0		=> pll_clk,
      		locked	=> pll_lock,
      		phasedone => pll_phasedone
      end rtl;
      And just in case the TB code as well:
      architecture TB of PLL_TEST_TB is
      	signal clk_50 : std_logic := '1';
      	signal lvds_clk_p, lvds_clk_n : std_logic_vector(0 downto 0) := "1";
      	signal step, updown : std_logic := '0';
      	signal cntsel : std_logic_vector (2 downto 0) := "010";
      	-- Procedure for clock generation
      	procedure clk_gen(signal clk : out std_logic; constant FREQ : real; constant DELAY : real) is
      		constant PERIOD    : time := 1 sec / FREQ;        -- Full period
      		constant HIGH_TIME : time := PERIOD / 2;          -- High time
      		constant LOW_TIME  : time := PERIOD - HIGH_TIME;  -- Low time; always >= HIGH_TIME
      		constant DELAYE	   : time := DELAY * 1 ns;
      	begin
      		-- Check the arguments
      		assert (HIGH_TIME /= 0 fs) report "clk_plain: High time is zero; time resolution to large for frequency" severity FAILURE;
      		-- Generate a clock cycle
      		wait for DELAYE;
      		loop
      			clk <= '1';
      			wait for HIGH_TIME;
      			clk <= '0';
      			wait for LOW_TIME;
      		end loop;
      	end procedure;
      begin
      	-- Clock generation with concurrent procedure call
      	clk_gen(clk_50, 50.0e6, 0.0e0);
      	clk_gen(lvds_clk_p(0), 150.0e6, 0.0e0);
      	clk_gen(lvds_clk_n(0), 150.0e6, 0.0e0);
      	--Instantiante UUT
      	UUT: entity work.PLL_TEST
      	port map(
      		lvds_clk_p => lvds_clk_p,
      		lvds_clk_n => lvds_clk_n,
      		clk => clk_50,
      		step => step,
      		updown => updown,
      		cntsel => cntsel
      	Testing : process is
      	begin
      		wait for 30 ns;
      		wait until rising_edge(clk_50);
      		updown <= '1';
      		step <= '1';
      		step <= '0';
      		step <= '1';
      		step <= '0';
      		step <= '1';
      		step <= '0';
      		updown <= '0';
      		wait for 100 ns;
      		assert false report "Test Complete" severity failure;
      	end process Testing;
      end architecture TB;
