17 years agoPLL dedicated output - Cyclone III
This is not the first time when someone posts about this theme, but because it is not totally cleared I risk to repeat. Well, I got this warning message:
PLL "<name>" output port <name> feeds output pin "<name>" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance I have read several posts, and the CIII handbook, and as it says only the C0 can be dedicated clock. That is cleared. Because I don't have too much choice having CIII dev. board, the output is connected to HSMB# 39 pin, what is J22 on the FPGA. Of course I got the warning message. So, just because I was curious, I removed the pin assigment let the fitter choose the approriate pin. Nothing is changed I still get the warning message. Never mind... The question is guys (though as I told I don't have choice, so I'm just curious) really how can I find which pin is the# X PLL C0 (ded. clk out) on the device? How it is marked for example in the Pin Planner?2 Replies
Thank You Ben, this is very much cleared!
Look at the pin out document for your device
eg http://www.altera.com/literature/dp/cyclone3/ep3c40.pdf Then look for pins called PLLx_CLKOUTn & PLLx_CLKOUTn. These are the dedicated output pins for PLL x.
