9 years agoPLL clock switchover with automatic derivation of PLL clocks is not working
Hi all, I'm using a Cyclone V and need to switch between two input clocks. The clocks have the same parameters. I adhered to the timequest cookbook which says the following: #create a 10...
9 years agoThese are the names I used in my design. I named them after the actual pin names of the FPGA. Is it possible that Quartus is confused therefore?
I'm not sure which PLL parameters you mean. I attached a file with the counter settings and some other parameters. (https://www.alteraforum.com/forum/attachment.php?attachmentid=13357 ) If you need to know other parameter settings just let me know.
