9 years agoPlease tell me, about Quartus Prime Ver UP.
My PC instelled Quartus Prime 15.1 , but I need change it, want to Quartus Prime 16.1.:confused: I must Quartus Prime 15.1 uninstall → 16.1 full install? or Quartus Prime 15.1 as i...
9 years agoIf you have enough disk space, you can leave 15.1 installed and install 16.1 beside it (assuming you want to have access to either 15.1 or 16.1).
Or just uninstall 15.1 if you don't plan to use it after 16.1 is installed (which I assume is likely the case). For legacy device support, I have both 13.0sp1 and 16.0 installed, and just play with ENV variables to select which version I need to use for a particular design.
