Chaitanyaeinfo's avatar
Chaitanyaeinfo
3 years ago
Please provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N.
1)Please provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N.
2)As per the customer "There are only 6 substances confirmed for ROHS of this material, please help confirm whether there are 10 substances confirmed.
Or can you confirm the following ROHS version? EU directives 2011/65/EU and amendment 2015/863/EU"
Kindly advise Does this part has an ROHS version of EU directives 2011/65/EU and amendment 2015/863/EU.
Note: We are one of your distributors. If you are not able to answer the above questions, then please provide the direct email contact (Compliance team)who can help us in this case.
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
    Nazrul Naim
    NazrulNaim_Intel
    For your information, this product is RoHS Compliant with RoHS Directive 2011/65/EU and as amended by Directive 2015/863. For the material Declaration Sheet can be obtained through the link below.
    Link : https://cdrdv2.intel.com/v1/dl/getContent/693838?fileName=EP20K160EFC484-2N_20191130040555_v1.xml
    Below is the step how to open XML file in Excel
    1. Open a new blank Excel file
    2. Click on Developer tab, then click Import
    3. Select the xml file you want to import, then click Import
    4. Click "OK" on pop-op information, and also "OK" on where to Import data
    5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
    6. I recommend to delete column AK so that the other columns will display better:
    Hope that answers your question.
    Nazrul Naim
    NazrulNaim_Intel
    Sorry for the delay. Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
    Thank you for your patience.
    Nazrul Naim
