Chaitanyaeinfo
3 years agoPlease provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N.
1)Please provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N. 2)As per the customer "There are only 6 substances confirmed for ROHS of this material, please help...
NazrulNaim_Intel
3 years agoHello,
For your information, this product is RoHS Compliant with RoHS Directive 2011/65/EU and as amended by Directive 2015/863. For the material Declaration Sheet can be obtained through the link below.
Link : https://cdrdv2.intel.com/v1/dl/getContent/693838?fileName=EP20K160EFC484-2N_20191130040555_v1.xml
Below is the step how to open XML file in Excel
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better:
Hope that answers your question.
Nazrul Naim
