12 years agoPin Planner LVDS Differential Pair Selection
I am fighting Pin Planner at every turn. In my QSF file, I have the following: set_location_assignment PIN_T22 -to "HSMC_RX_D_N(n)"
set_instance_assignment -name IO_STANDARD LVDS -to "HSMC_RX_D...
12 years ago --- Quote Start --- 1. Set the VCCIO jumper to 2.5V to allow LVDS constraint on the HSMC pins. --- Quote End --- I was reading the tutorial that came along with the software; I thought the input signals should be 1.5V (both digital and analog), so I set everything to 1.5V. Only the analog signals are 1.5V. I have changed the jumpers to 2.5V again. --- Quote Start --- 2. Manually solder the 100-ohm terminations onto the board. --- Quote End --- I am fearful of soldering anything to the FPGA because it may be used for many other projects. My pin planner looks like garbage. I think there are 3 levels of (n)s. However, the darn thing works. I tested the speeds up to 50 MHz in (300 MHz out) and without using termination, the signals appear to arrive at the FPGA correctly. After the code is complete I will do extensive testing, and if we require 100 Ohm resistors, we will (painfully) attach them. Again, thank you for your help. I don't know how it's working, like I said pin planner looks like garbage. But it is. Moving on. Not touching it. -Joe
