12 years agoPin Planner LVDS Differential Pair Selection
I am fighting Pin Planner at every turn. In my QSF file, I have the following: set_location_assignment PIN_T22 -to "HSMC_RX_D_N(n)"
set_instance_assignment -name IO_STANDARD LVDS -to "HSMC_RX_D...
12 years ago --- Quote Start --- I think I am confused --- Quote End --- No problem, lets try to resolve that ... :) --- Quote Start --- The only thing I'm trying to do is see the single ended signals. --- Quote End --- Hang on, you're changing your requirement here ... Your interface has to either be defined as differential LVDS, in which case you cannot view the output signals unless you have a termination resistor across the output pair, or you want your signals as single-ended. So what is your requirement? Cheers, Dave
