12 years agoPin Planner LVDS Differential Pair Selection
I am fighting Pin Planner at every turn. In my QSF file, I have the following: set_location_assignment PIN_T22 -to "HSMC_RX_D_N(n)"
set_instance_assignment -name IO_STANDARD LVDS -to "HSMC_RX_D...
12 years ago --- Quote Start --- How do I make Pin Planner stop being so mean to me? --- Quote End --- You cannot. Its sole purpose in life is to frustrate you :) For LVDS signals, you only need to assign the pin and IO_STANDARD to the positive side of the pair, and Quartus will infer the negative pin assignment. This means your top-level entity does not need to include your two signals, i.e., HSMC_RX_D_P and HSMC_RX_D_N, you can just call it HSMC_RX_D and make it LVDS. You then do not need an iobuf at the top-level of your design. There are other solutions, but this one results in the least code :) Cheers, Dave
