9 years agoPin placement with altera lvds core
I can't figure out how to connect pins up to the altera lvds core. Every time I try the fitter complains it cannot place 1 periphery component due to conflicts with existing constraints. If I delet...
9 years agoI believe you are correct here, removing the clock input cleared the error. I was able to hook the input clock up to G15 and it seemed to work but how do I figure this out from the datasheet? I didn't see anything in the datasheet for the cyclone V and I was looking through Clock Networks and PLLs in Cyclone V Devices but it mostly just talked about how they worked not how to translate pins to lvds locations.
Thank you
