9 years agoPin placement with altera lvds core
I can't figure out how to connect pins up to the altera lvds core. Every time I try the fitter complains it cannot place 1 periphery component due to conflicts with existing constraints. If I delet...
9 years agoThere are more statements after this error message. Please copy the whole error sub-messages and put them in here.
Suggested solution: ALTLVDS_TX or RX uses PLL. You may be already using the PLL that is available in the bank, then the fitter will not be able to use the correct PLLs
