Pin "K3" of FPGA "10M25DAF484"
Hi Nakamura_kimi,
I would recommend to look to the similar thread: Will the 5CEFA4U19 chip work without some power pins connected as suggested by the Quartus migration feature.
I would recommend to look to Intel MAX 10 FPGA Device Family Pin Connection Guidelines (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf).
There is the following fragment as an explanation of NC pin, section Reference Pins, p.12:
Pin Name = NC, Pin Type = No Connect, Pin Description = Do not drive signals into these pins. Connection Guidelines = When designing for device migration, these pins may be connected to power, GND, or a signal trace depending on the pin assignment of the devices selected for migration. However, if device migration is not a concern, leave these pins floating.
Martin
Hello Nakamura,
Has your question been resolved?
- nakamura_kimi5 years ago
Hello
It was almost resolved.
Thank you
- AminT_Intel5 years ago
