17 years agoPin (I/O) VCC33 and GND using as power supply
- How much is the maximum current gives from the Expansion Header pin VCC33?
- Can I use GND and VCC33 as power supply to my circuit (it needs 52 mA)? - Where can I find the data sheets?3 Replies
Yes, the connector can source a much higher current in most designs, cause VCC33 is most likely not working to capacity.
I'm working with ALTERA DE2 (Development and Education Board) with the Cyclone II EP2C35F672C6. I'm talking about the 40-pin expasion header (VCC5 = PIN 11, VCC33 = PIN29 ang GND = PIN12 and PIN30).
I was looking the CD DE2 Systems on the file DE2_schematics\DE2_schematics.pdf, page 20 (POWER) found the LM2676 working as voltage regulator 3.3 V, so looking the data sheets, it is capable of driving up to 3A. So, I guess I found the answer to my question. I hope it's right. - Altera_Forum
You're apparently referring to a particular Dev Kit, but forgot to mention what it is.
