17 years agoPin (I/O) VCC33 and GND using as power supply
- How much is the maximum current gives from the Expansion Header pin VCC33? - Can I use GND and VCC33 as power supply to my circuit (it needs 52 mA)? - Where can I find the data sheets?
17 years agoYes, the connector can source a much higher current in most designs, cause VCC33 is most likely not working to capacity.
