Pin functionality details for 5CEBA7F27C8N
For 5CEA7 FPGA series, considering the pin out for part number 5CEBA7F27C8N, there are Clock and PLL Pins which are mentioned with I/O, Clock function. could you please confirm if these are not used for clock functionality, can these be used as general purpose I/O pins
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- AqidAyman_Altera
I wish to follow up with you on this question.
Do you need any more support?
Aqid
- AqidAyman_Altera
You can refer to the Pin Connection Guidelines for Cyclone V through link below:
If you are referring to the pin name "CLK[0:11][p:n]", then it mentioned there that these pins can also be used for data inputs or outputs.
Aqid
- FvM
functionality of each pin type is listed in Cyclone V pin connection guidelines. Clk input pins e.g. can be only used as input but not output.
- givememessage
5CEBA7F27C8N $232.25, contact [email protected]
