ShivaKi
2 years agoPin functionality details for 5CEBA7F27C8N
For 5CEA7 FPGA series, considering the pin out for part number 5CEBA7F27C8N, there are Clock and PLL Pins which are mentioned with I/O, Clock function. could you please confirm if these are not used ...
AqidAyman_Altera
2 years agoHi,
You can refer to the Pin Connection Guidelines for Cyclone V through link below:
If you are referring to the pin name "CLK[0:11][p:n]", then it mentioned there that these pins can also be used for data inputs or outputs.
Aqid
