KenBee's avatar
KenBee
1 year ago
pin assignments
Using Quartus 13.1 to program Cyclone IV.
Fitter reports - Trigger: missing drive strength and slew rate.
Pin Planner - Trigger (output pin) - Current strength 8mA, slew rate 2. (i,e, defaults)
I have tried changing the assignments and trying the fitter again but no better. Tried using a different PC, still no good. The program produces a .pof file and says the EPCS16 programmed OK, but the output is fixed high. I am presuming the above problem is the culprit.
Help would be gratefully received , but please keep it simple - I am not a programmer!
Ken
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    AqidAyman_Altera
    Wish to follow up.
    Do you still need help on this question?
    Thanks for your response.
    AqidAyman_Altera
    Hi Ken,
    Any updates on this issue? Do you still face it? If yes, can share your codes or any details that might help us to understand your issue?
    Aqid
  • sstrell's avatar
    sstrell
    Is "trigger" the name of an output signal? You should probably show some code to understand what is happening here.
