16 years agopin assignment problems,help!
quartus ii shows the following error: Error: Output or bidirectional pin out_port_from_the_led_pio[1] in pin location P12 (pad_105) is too close to VREF pin in pin location T11 (pad_106) Error:...
15 years ago --- Quote Start --- that problem should be a serious fault terasic made. How can they assume that we would not use both of the parts at the same time! I am really confused --- Quote End --- There are more concurrent requirements for a dev kit than for a user board. It may be impossible to meet all of them at the same time. However, if you're able to assume the LED output as a static signal that won't disturb RAM operation, you may want to give it a toggle rate 0 mhz assignment, and the fitter will ignore it.
