16 years agopin assignment problems,help!
quartus ii shows the following error: Error: Output or bidirectional pin out_port_from_the_led_pio[1] in pin location P12 (pad_105) is too close to VREF pin in pin location T11 (pad_106) Error:...
15 years agothank you for your replying and answering! I solved the problems with almost the same method to you times ago. Although I know little about the hardware design in FPGA project, that problem should be a serious fault terasic made. How can they assume that we would not use both of the parts at the same time! I am really confused!
