16 years agopin assignment problems,help!
quartus ii shows the following error: Error: Output or bidirectional pin out_port_from_the_led_pio[1] in pin location P12 (pad_105) is too close to VREF pin in pin location T11 (pad_106) Error:...
15 years agoI have met the same situation about this.Your warning is nearly as the same as mine.At the beginning, I thought it may be my niosII design.But when I saw a cyclone III example,I found that it is not possible to have a 4 bit wide LED pio,because the LED pins are too close to the SDRAM pins.So I think it may be the sdram and led are confliction in some extent.I change 4 led to one led,then I compile passed!
