16 years agopin assignment problems,help!
quartus ii shows the following error: Error: Output or bidirectional pin out_port_from_the_led_pio[1] in pin location P12 (pad_105) is too close to VREF pin in pin location T11 (pad_106) Error:...
16 years agoTypically one of this cases brings up problems like you have reported:
- You have a development kit with a basically functional reference design and applied arbitrary changes without understanding exactly, how the design works. - You let the MegaWizard generate a DDR RAM interface, but skipped some of the suggested steps. - You tried to assign all location and IO-standards manually without understanding the requirements. It's not clear from your post, which case applies here.
