14 years agoPin assignment help needed
Hello, I am new to quartus and would require help with the pin assignment feature(using pin planner). I have created a certain design. In the design it is required that certain inputs are always...
14 years agoHello,
So I incorporated VCC and GND in my schematic. After compilation when I see the pin finder window, the Vcc and Gnd options do not exist in the pin finder window nodes. So my guess is it(Quartus) implicitly assigned a high logic and Gnd and there is no need to explicitly make the connection to the VCC in schematic to a VCC in the pin diagram. Am I right? There is also one more thing I wanted to ask. I need outputs to communicate with another device(AD9910 manufactured by Analog Devices). I have a HSMC prototyping board. How do I know which pins in the FPGA correspond to the prototyping board pins. For eg: I require a CMOS 3.3V output. The HSMC data sheet says that it is pin 41 in the HSMC bank. I need to tie one of my outputs to pin 41 of the HSMC board. How do I figure the appropriate pin to be assigned in the pin planner so that pin 41 of the HSMC board(which I have interfaced with the FPGA) will reflect my desired output? Thanks and Regards Ranjan
