14 years agoPin assignment help needed
Hello, I am new to quartus and would require help with the pin assignment feature(using pin planner). I have created a certain design. In the design it is required that certain inputs are always...
14 years agoIf you want something to work right away, you can always make a schematic file, click and drag over an output pin and tie it to VCC. In the pin planner, you'll be able to select the correct voltage for that pin.
--- Quote Start --- Hello, I am new to quartus and would require help with the pin assignment feature(using pin planner). I have created a certain design. In the design it is required that certain inputs are always high and certain are always low. I thought of connecting the high inputs to VCC and low to ground. But when I wanted to make that assignment I find that the pins which are shown by in the pin planner layout as vcc or ground cannot be accessed in the location column(The place where the pin number is written). Is there any other way I can assign a permanent high or permanent low to the inputs. I am using the Altera Cyclone 3 FPGA starter kit. I would highly appreciate some inputs. Thanks and Regards Ranjan Banerjee --- Quote End ---
