akochubey
4 years agoPHYLite LVDS input
Hi All,
I'm trying to integrate AD9613 ADC (250 MHz LVDS DDR interface) to Cyclone 10 GX device and I would appreciate any help on fixing timing for that.
I've tried to implement the interface us...
akochubey
4 years agoHi Ash_R_Intel,
thank you for your answer, I will re-read these docs.
Should I be able to close 250 MHz timing using GPIO Intel FPGA IP?
So far the best I could get was [-0.72 Setup slack, -0.286 Hold slack] for "Slow 100C" corner (so I need about +1 ns into valid data window). Any clue on what is to be tried?
Please would you also confirm that:
1. It is not possible to use PHYLite core with LVDS inputs (need to convert them to something like HSTL on the board level).
2. I need both clock and strobe come from outside of the chip, if using PHYLite
Thanks in advance,
Anatoly
P.S. the chip is 10CX220YU484I6G
