15 years agophase problem about transceiver of stratix ii GX
Hi, I need help for a problem
I use transceiver of stratix ii GX for high speed output, and need four channels. The output of transmitters is right, but the phase are different for different channels, which i can understand and handle. But my problem is that when I reboot the FPGA(power off then power on), the phase relationship between channels change. It looks like everytime I reboot the FPGA, the phase relationship is random. I can't understand the reason for that. So can anyone give me some help about the reason and method to solve this problem. I just need to make the phase relationship between channels fixed rather than random. Thank you11 Replies
The behavior is most likely due to the phase compensation FIFO inside the transceiver. They come out of reset at different times.
Jake
