15 years agophase problem about transceiver of stratix ii GX
Hi, I need help for a problem I use transceiver of stratix ii GX for high speed output, and need four channels. The output of transmitters is right, but the phase are different for different ch...
15 years agoYou are not the first to tackle this problem. A search of the forum will reveal other similar discussions. The problem I believe is that the individual transceiver channels actually have internal reset circuitry. The serializers are coming out of reset at different (random) times. I do not believe you have access to control this.
Protocols that require strict channel-to-channel skew requirements typically use bonding. It sounds like you obviously have control of the receiver as well if you're able to tolerate a fixed skew. Can you implement dynamic phase alignment at the receiver? Jake
