15 years agophase problem about transceiver of stratix ii GX
Hi, I need help for a problem I use transceiver of stratix ii GX for high speed output, and need four channels. The output of transmitters is right, but the phase are different for different ch...
15 years agoDo you reset the Transceiver (respectively release the reset) after a stable reference clock is present? I would assume this as a prerequisite to achieve predictable timing relations. It may be the case, that Stratix II doesn't provide it anyway.
