15 years agophase problem about transceiver of stratix ii GX
Hi, I need help for a problem I use transceiver of stratix ii GX for high speed output, and need four channels. The output of transmitters is right, but the phase are different for different ch...
15 years agoI instantiated five transmitter channels using alt2gxb module. Four of them are in the same quad.
I don't need to remove the phase difference between channels, I just want to get a fixed difference. Now the situation is like this, say the time difference between the serial output of channel 1 and channel 2 is 4 ns (channel 2 delay 4 ns). if I turn off fpga and reboot it again, this time difference will change to other value, such as 2 ns, and channel 2 may be ahead this time. Every time I reboot FPGA, the time relationship between channels are different, even for the four channel in same quad. I can understand there are time difference for the output of channels, but I can't understand why this difference change random. Thanks
