17 years ago
Phase modulation
The attached picture shows phase modulation of a clear clock by a sinusoidal signal.
Would you plz help me figure out what kind of circuit does this?
I know there r generators that can generate this kind of signal but I want to know whats the basic -easiest- way to achieve such modulation.
I also have some questions:
1. UI is the time of one period of the clock. Right? so 2/3 is chosen such that the maximum modulation doesnt result in losing a clock period or adding another one?
2. isnt the period supposed to be 1/fc (for the ideal clock)? why is it considered 2pi in this case?
Thank you.
    The sin(2*pi*fc*t) indicates the fundamental sinusoid component of the clock signal. This is a standard equation and the 2*pi allows the sine values to cycle around...
    The picture explains a clean clock jitter on the basis of two sinusoid phase modulation. You can see there is a clear relationship between clock jitter and the amplitude of the modulating sinusoid.
    In the digital domain you can reproduce that in a DDS circuit(Direct Digital Synthesiser) by generating the clock "sinusoid" component according to word value decided by a lut containing one cycle of the modulating sinusoid amplitude values).
    edit: alternatively, use altera NCO and set to phase modulation then pass the phase modulation value as variable input from the LUT. (altera NCO is an implementation type of DDS)
    Kaz
    The diagram text is wrong. It says sin() but shows a square wave. The term jitter is used normally for an unwanted phase modulation.
    I can't see, if the diagram is intended as an example to explain phase modulation or clock jitter analysis or if it shows a generated signal with specific parameters. Thus I can't comment the 2/3 modulation index, apart from confirming that it has to be below unity.
    The question, how to generate a similar signal may be answered different, depending on the required application parameters.
