17 years agoPhase modulation
The attached picture shows phase modulation of a clear clock by a sinusoidal signal. Would you plz help me figure out what kind of circuit does this? I know there r generators that can generate ...
17 years agoThe diagram text is wrong. It says sin() but shows a square wave. The term jitter is used normally for an unwanted phase modulation.
I can't see, if the diagram is intended as an example to explain phase modulation or clock jitter analysis or if it shows a generated signal with specific parameters. Thus I can't comment the 2/3 modulation index, apart from confirming that it has to be below unity. The question, how to generate a similar signal may be answered different, depending on the required application parameters.
