rshal2
6 years agoPeloader hang in clock calibration
Hello, The following function get hang in my application. I can't knows exactly why, because preloader is getting compiled with debug information (Is there a way to Turn it off)? What I see is: ...
FawazJ_Altera
6 years agoHello sir,
The pll input clock should be 25MHz based on our reference design. Anything below or above might not function properly since there was no test achieved to verify. Is it possible to change the PLL input clock on your board (to make it 25MHz)?
Thank you
- rshal26 years ago
The issue seems to be solved.
The real problem was that in platform designer HPS clock was set as 25M, while the real clock was 50M.
On changing qsys hps clock to 50M , the issue been solved.
