andrehfg's avatar
andrehfg
5 years ago
PCN118144/PCN118143 Patch for Quartus Prime 17
I used Quartus Prime Standard 17.0 (Quartus Prime Version 17.0.0 Build 595 04/25/2017 SJ Standard Edition(windows)) and Quartus Prime Pro 17.1 (Quartus Prime Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition (linux)) in a design and I'like to know if these versions are affected by the issues described in PCN 118144-01 and PCN118143-01. If they are affected, could you make the screening patches and the solution patches available?
    • andrehfg's avatar
      andrehfg
      Attached you'll find the PCNs.
      • AminT_Intel's avatar
        AminT_Intel
        PCNs you given me notified update on Intel Quartus Prime Standard Edition version 1(9.1 and earlier) from PCN118143-01 and Intel Quartus Prime Pro (version 20.1 and earlier) and Intel Quartus Prime Standard (version 19.1 and earlier) from PCN 118144-01.
        You mentioned that you are using Quartus Prime Standard 17.0 and and Quartus Prime Pro 17.1. Thus, both of these versions you are using affected by these two PCNs you have received. There are KDB Article in PCNs you provided that has the KDB and it patches that you can refer to for each issues raised. Please refer to those links and download the new patches.
        I hope this answer your question.
        Thank you.
