14 years agoPCIe interface in Cyclone IV
hi, I want to configurethe PCI express interface of Cyclone IV GX (EP4Cgx150CF23C7N) FPGA. Can I use any of the transceiver pins (eg. GXB_RX, GXB_TX, etc.) or are there any specific pins? I am not...
14 years agoHi,
Are you using the soft IP or the hard IP? If using the Cyclone IV GX, I'd recommend using the hard IP. Then you'll be using all those transceiver pins you mentioned. I'd recommend you start with this Altera PCIe reference design "PCI Express to DDR2 SDRAM Reference Design". Read the User Guide for this ref des and also the Altera PCIe Compiler User Guide to get started. You don't have to bother with the PCI/PCIe spec for now. See the link below for more details. http://sites.google.com/site/ednalabs/project/fpga/tips/pcie-design-with-altera --- Quote Start --- hi, I want to configurethe PCI express interface of Cyclone IV GX (EP4Cgx150CF23C7N) FPGA. Can I use any of the transceiver pins (eg. GXB_RX, GXB_TX, etc.) or are there any specific pins? I am not able to find it in the handbook. --- Quote End ---
