Avi_V_888
4 years agoPCIe gen 4-6 lanes Agilex: maximum number of clks ready signal disabled
I using PCIe gen 4 (16 lanes) (512bit/500MHz clk , payload size:256B) CORE, in Agilex device: AGFB014R24A2E2VR0.
Tests performed found that the maximum number of clks that "ready" sig...
Harris
4 years agoHi Avi,
Yes. It is possible that you can use TX flow control interface to allocate the transmission in advance, instead of depending on 'ready' fully in your situation. For TX flow control interface, please refer to user guide. Thanks.
BR/Harris
Avi_V_888
4 years agoHi Harris,
The source that feeds the PCIe core in data (and from there the core transfers it to the PC) works in real time mode.
Therefore TX flow control interface will not help here.
The problem will be solved if it will be possible to configure the core so that the ready signal will not be '0' for such a long time continuously.
Avi
