16 years agoPCIe Driver
Hi, I'm trying to reuse the older design which uses PCIe x1 in Arria II GX. In new design, I will be using x8 with same part(Arria II GX). We used jungo driver for x1 lane. If I go with x8, ...
16 years agoYou might need to change the device ID for the new card and this change will be reflected in your inf file. I guess there should not be any change in the driver source code. The jungo driver does not know if the card is a PCIe x1 or PCIe x8 or PCI card.
