12 years ago
PCIe Address Translation Services ... support for ?
I am looking at employing "Address Translation Services" (ATS), per the PCISIG 1.1 definition ...
I can't see any reference in searches or the PCIe user guide . Since this is a new feature, I'm figuring it may
not be in the available Hard PCIe IP , but supported by the PCIe Soft IP , something I have no experience with .
For an endpoint to take advantage of ATS, there needs to be some method to modify the Read / Write TLP to indicate if the address
is translated or untranslated ( default ), and the third case of a Read translation request where the completion doesn't contain read
data, but a translated address that can then be cached in the endpoint.
Where should I go to get information on ATS support in Altera PCIe solutions ?
Thanks, Bob.
1 Reply
    This Forum ( and search engines ... ) seems to be silent on the subject.
    I would like to run translated reads / writes from the endpoint and believe it must be supported. I can understand if the Hard IP doesn't have the support
    but would expect the Soft IP to ... I guess I need to get the Soft IP users guide to see what it says ...
    Below is the URL to the PCISIG information and a summary of what it is.
    http://www.pcisig.com/specifications/iov/ats/
    "PCI-SIG I/O Virtualization (IOV) Specifications, in conjunction with system virtualization technologies, allow multiple operating systems running simultaneously within a single computer to natively share PCI Express® devices. The Address Translation Services (ATS) specification provides a set of transactions for PCI Express components to exchange and use translated addresses in support of native I/O Virtualization."
    The attached image indicates bits 2 and 3 in the third byte of a READ/ WRITE ( Address Type, AT bits ) are used to support ATS for reads and writes.
    For reads, I would
    1. make the the translation request with AT bits = 2'b01, and the read data would be the translated address ( not the read data ).
    2. endpoint then caches the translated address and subsequently makes reads with AT bits = 2'b10 using the translated address.
    3. PCIe RC passes read request on to IOMMU as translated and the IOMMU bypasses any translation look-up or table-walk using the translated address from the endpoint.
    4. Read completion returned as normal.
    Does anyone know how I would control the AT bits or if that only achievable with the Soft PCIe IP ?
