PCB Design using Cyclone III (EP3C120) concerns
Hello, I'm a bit concerned about PCB specifications for a Cyclone III EP3C120.
My goal is to build a PCB with an EP3C120 and being able to download a configuration (initially using a .sof file through USB Blaster) to the fpga and connect some of the IO pins to some headers on the PCB, research and testing purposes only. Later we would include an external flash memory to save configurations on the board but first things first. Now my concerns are the following: - I read that trace length and impedance matching are an important concept over PCB's while hosting high speed digital systems, how important are these two?, are there any software tools to help me get over this? - What about power sources? I've read that a specific sequence is required, but I want to hear some of your experiences, voltage tolerance, etc. - Switching noise: should a ground plane and appropiate trace lenght and clearance are okay to prevent this? In a few words, i just want some guidelines and critical components needed to build a minimum system for an FPGA. Is it good just to start with some power sources, the FPGA, appropiate bypass capacitors, a JTAG header, and watch for trace impedance matching? I hope I'm not asking too much, as you may know this is my first project using these type of devices... Maybe I'm just freaking out.5 Replies
Thanks a lot for your reply rbugalho, I will be taking these tips seriously and make use of the tools that Altera offers for my design, and hopefully will get it going!. My design doesn't use LVDS signals but as it is a first try, the traces lenghts will likely remain as small as possible.
Some older Altera FPGAs were picky about sequence but Cyclone III does not require any specific power up sequence.
Requirements are just that it's monotonic. Cyclone III needs 1.2V for core, 1.2V and 2.5 for PLLs and then 1.2/1.8/2.5/3.0/3.3V for the I/O banks, depending on your configuration. Any decent switched converter will do, provided it can work with the spec (ie, 1.15 -- 1.25 for VCCINT). Power supply and signal integrity issues depend on the frequencies you'll be operating at and also the I/O standards you're using. LVCMOSL I/Os generate much powerfull noise than LVDS. General rules apply. - Use decoupling capacitors and inductors, as much as possible, to filter the power supply lines. Try to use Altera's PDN tool to size them up. - If you're using non-terminated I/Os (ie, LVCMOS) try to keep the traces as short as possible. These I/O standardads don't use matching impedances and reflections are unavoidable. - If you're using terminated I/Os (ie, LVDS) then you can have long traces with good signal integrity, provided you match the line impedance. - In any case, make sure any fast swtiching signal line has a good ground/power plane. Or, if you really really have have to cross a plane discontinuity, put stitching capacitors. Note that JTAG and PROM interface VCCIO as every other pin in bank 1. With Cyclone III, you should add external clamping diodes on the JTAG pins, if you're using 2.5V or higher. The schematics of development boards, (ie, DE-0) are online, and you can use them as starting point. As soon as possible in your PCB design, and definitely before you sign it off for production, you should at least make a mock up project, do the pin assignment and compile it. Then cross check your PCB design with the .pin report file produced by Quartus and the Cyclone III pin connection guidelines. - Altera_Forum
--- Quote Start --- That seems reasonable to me, but what would you recommend me for the power supply section? Some DC/DC Converters that you have used already? I understand that ripple must be minimized and the power-up sequence it's important, also that EP2C120 requires 1.2V for internal power and its PLL and finally 1.8V and 2.5V for its I/O banks. Thanks a lot for your help --- Quote End --- Have a look at the power analysis tool, if you plug in rough values for your design it'll tell you how much current each power rail requires. I usually use a switcher for VccInt then linear regulators or switchers depending on the board VccIO requirement. The power up sequence isn't important as far as I know (as long as the supplies come up fairly qickly). You'll end up having to read a lot of the documentation I'm afraid! Nial. - Altera_Forum
Thanks a lot for your help - Altera_Forum
--- Quote Start --- In a few words, i just want some guidelines and critical components needed to build a minimum system for an FPGA. Is it good just to start with some power sources, the FPGA, appropiate bypass capacitors, a JTAG header, and watch for trace impedance matching? I hope I'm not asking too much, as you may know this is my first project using these type of devices... Maybe I'm just freaking out. --- Quote End --- The first thing I place when doing an FPGA PCB design is the config prom and the JTAG header and get these as close to the device as possible (within the limitations of the design). If you keep these interfaces short you won't have to worry about track impedances/ reflections etc. Nial.
