17 years agoPausing target processor not responding in stratix 2
Hi all, Im a new user in FPGA board. Currently i have a problem regarding my project. I able to generate and download my .sof file into my fpga board without any error. Then i also manage to bu...
17 years agoHere how it goes, previously i mentioned that i can run the program using "on chip memory" and the problem occurs when i add DDR SDRAM. So it seems like i have problem with my DDR SDRAM. I figure out that my problem is caused by my top level module which i wrongly assign one of the signal, "global_reset_n_to_the_ddr_sdram". i had include my top level module for your view.....but i need some explaination based on this problem ?? All the best for all beginers like me... :)
-------------------------------------------------------------------------------------------------------- module system( // 1) global signals: clk, reset_n, // the_ddr_sdram_0 ddr_a, ddr_ba, ddr_cas_n, ddr_cke, clk_to_sdram_n, clk_to_sdram, ddr_cs_n, ddr_dm, ddr_dq, ddr_dqs, ddr_ras_n, ddr_we_n ); // 1) global signals: input clk; input reset_n; // DDR SDRAM // i/o signal output [12: 0] ddr_a; output [ 1: 0] ddr_ba; output [ 1: 0] ddr_cas_n; output [ 1: 0] ddr_cke; inout [ 1: 0] clk_to_sdram_n; inout [ 1: 0] clk_to_sdram; output [ 1: 0] ddr_cs_n; output [ 1: 0] ddr_dm; inout [15: 0] ddr_dq; inout [ 1: 0 ] ddr_dqs; output [ 1: 0 ] ddr_ras_n; output [ 1: 0 ] ddr_we_n; //wires wire ddr_sdram_aux_full_rate_clk_out; wire ddr_sdram_aux_half_rate_clk_out; wire ddr_sdram_phy_clk_out; wire dll_reference_clk_from_the_ddr_sdram; wire [ 5: 0] dqs_delay_ctrl_export_from_the_ddr_sdram; wire local_init_done_from_the_ddr_sdram; wire local_refresh_ack_from_the_ddr_sdram; wire local_wdata_req_from_the_ddr_sdram; wire reset_phy_clk_n_from_the_ddr_sdram; wire global_reset_n_to_the_ddr_sdram; system_file the_system_file ( //global signals: .clk (clk), .reset_n (reset_n), //DDR SDRAM //wires .ddr_sdram_aux_full_rate_clk_out (ddr_sdram_aux_full_rate_clk_out), .ddr_sdram_aux_half_rate_clk_out (ddr_sdram_aux_half_rate_clk_out), .ddr_sdram_phy_clk_out (ddr_sdram_phy_clk_out), .dll_reference_clk_from_the_ddr_sdram (dll_reference_clk_from_the_ddr_sdram), .dqs_delay_ctrl_export_from_the_ddr_sdram (dqs_delay_ctrl_export_from_the_ddr_sdram), //HERE IS THE CHANGES THAT I HAD MADE // .global_reset_n_to_the_ddr_sdram (global_reset_n_to_the_ddr_sdram), .global_reset_n_to_the_ddr_sdram (reset_n), .local_init_done_from_the_ddr_sdram (local_init_done_from_the_ddr_sdram), .local_refresh_ack_from_the_ddr_sdram (local_refresh_ack_from_the_ddr_sdram), .local_wdata_req_from_the_ddr_sdram (local_wdata_req_from_the_ddr_sdram), .reset_phy_clk_n_from_the_ddr_sdram (reset_phy_clk_n_from_the_ddr_sdram), //io signals .mem_addr_from_the_ddr_sdram (ddr_a), .mem_ba_from_the_ddr_sdram (ddr_ba), .mem_cas_n_from_the_ddr_sdram (ddr_cas_n), .mem_cke_from_the_ddr_sdram (ddr_cke), .mem_clk_n_to_and_from_the_ddr_sdram (clk_to_sdram_n), .mem_clk_to_and_from_the_ddr_sdram (clk_to_sdram), .mem_cs_n_from_the_ddr_sdram (ddr_cs_n), .mem_dm_from_the_ddr_sdram (ddr_dm), .mem_dq_to_and_from_the_ddr_sdram (ddr_dq), .mem_dqs_to_and_from_the_ddr_sdram (ddr_dqs), .mem_ras_n_from_the_ddr_sdram (ddr_ras_n), .mem_we_n_from_the_ddr_sdram (ddr_we_n) ); endmodule -------------------------------------------------------------------------------------------------------
