14 years agoPausing target processor and other problems
I have problems with Nios programming. I'm developing an audio voice recorder with DE2 board. I use Quartus II Subscription Edition 9.0 and Nios II 9.0 EDS. First I programmed the Quartus ...
14 years agoI added the debug core, but now also the Hello world small gives the same error message.
using cable "usb-blaster [usb-0]", device 1, instance 0x00.pausing target processor: not responding.
resetting and trying again: failed.
leaving target processor paused. Then I made an own project using tut_sopc_introduction_vhdl.pdf . It gives the same error. I set the timing constraint fmax=50 mhz. Timing report tells me the actual time is 98.89 mhz. I connected the reset to toggle switch and tried to run the program, having the toggle switch in both positions. Again same error. I also tried another toggle switch, again the same error. The Quartus also tells me that i use time-limited megafunctions, although I'm using only CPU, JTAG-UART, Sysid, and two PIOs and on-chip memory. I didn't close the "open core plus ip" dialog.
