11 years agoPartial reconfiguration CRC error
I am using Stratix V FPGA, and using the partial reconfiguration feature while I got the CRC error when I do the partial reconfiguration. FPGA is connected with CPU through PCIe interface. My s...
11 years agogood morning Alare,
Just wanted to get more information about your problem. Im familiar with partial reconfig but it seems it sound a little different from how you are using it. The way i use partial reconfig is by using the CVP method on the PCIe ip core. This allows for reconfiguration of the FPGA through two methods, Initialization mode and update mode. This will require for you to create a persona for the jic and rbf file. you then tell the driver on the PC to load the rbf file. IF you could post more info on how your planning to use it we can try to figure out. Thanks! -Trukng
